Can I pull additional Charge from the surrounding air to (add) power fuel cell?
Discussion in 'Off-Topic' started by JoMy, Nov 10, 2014.
Thread Status:
Not open for further replies.
  1. JoMy
    Nov 10, 2014
    I'm putting together a PLL Fuel Cell using high voltage ignition coil. So if I have an negative exposed wire antenna at the front of my car and a positive exposed wire at the back of the car, can I collect additional charge from the air as I move through space?
    So my phase locked loop circuit resonates the Ignition coil/Fuel Cell (LC circuit) while the detector is hooked up to either side Anode/Cathode of fuel cell to detect optimum LC resonance. Further to this I want to use two pancake coils so that it keeps the LC circuit isolated from the car. The only direct connection is the PLL detector and on the negative Anode side I have a wire at front of my car and the positive Cathode I have a wire at the back of the car.
    PLL to pancake transmitter to pancake receiver (all built in cell) to ignition coil to 12,000V blocking Diode to fuel cell capacitor then the anode & cathode detector wires go back PLL on the detector side of the circuit. On the detector wires I also have Anode wire antenna at front of car and Cathode wire antenna at back of car.
    So the basic idea is I have a PLL auto-tuned Fuel Cell that collects additional charge from surrounding space as the car drives along basically creating a Tesla Sink that incorporates the local environment into the Fuel Cell circuit design.
    regards,
    Jomy
  2. joeyd999
    Jun 6, 2011
    2,758
    2,937
    First, it was Ayn Rand, through John Galt, who devised the concept of unlimited power from "static electricity" in the atmosphere.
    Second, any power generated via motion of the car would have first been generated by the car's motor. You are not gaining anything. In fact, due to inefficiencies, you'd be far better off tapping power directly from a) the drive train, or b) the alternator.
  3. WBahn
    Mar 31, 2012
    18,089
    4,917
    Technobabble -- an since it's basically a claim at a perpetual motion contraption....
  4. alfacliff
    Dec 13, 2013
    2,449
    428
    this makes no sense at all. there is no pll circuit described.
    sounds more like a "free energy" device.
  5. joeyd999
    Jun 6, 2011
    2,758
    2,937
    But, a superconducting electromagnet bolted to the front of the car will pull the car forward. And the electromagnet only needs to be charged once, as there is no resistance to cause decay of current. I drove mine to work today.
  6. tom_s
    Member
    Jun 27, 2014
    287
    342
    me no thinks they like to modify car bits :)
  7. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
Thread Status:
