Can I pass liquid through fiber optic strands?
Discussion in 'General Science' started by JJoll, Aug 25, 2016.
  1. JJoll
    May 7, 2013
    43
    I am a university research student and for my project I need very thin microtubes. Similarly to the ones that you can find in this website: https://www.raumedic.com/technologies/extrusion/micro-tubing/
    I need a microtubing with inner diameter of approximately 0.5mm and outer diameter of less than 0.8mm. I need to pass some sort of liquid through these tubes and I was just wondering if I could use fiber optics strands for this purpose? I have not used fiber optics strands before but since they are hollow I thought it is possible to pass liquids through them, is it going to work?
    thanks
  2. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    Never heard of hollow strand glass fibers - but you might get some capilliary action in the spaces between the strands.
  3. MaxHeadRoom
    Jul 18, 2013
    10,841
    2,519
  4. SLK001
    Nov 29, 2011
    851
    243
    Fiber optic strands are NOT hollow. Where did you hear that they were?
  5. crutschow
    Mar 14, 2008
    13,496
    3,373
    Fiber optic strands may be referred to as a "light pipe" but that pipe is not hollow.
    The light reflects off the inner surfaces of the strand at very near 100% efficiency due to total internal reflection, allowing the light to travel down the strand and around corners as if it were a pipe.
  6. jpanhalt
    Jan 18, 2008
    5,699
    909
    There are lots of real tubing options with ID's of 0.5 mm. Can you help us narrow the search? Depending on the flow rate you need, viscosity of your liquid, and distance the pressure required can get quite high.
    John
  7. KJ6EAD
    Apr 30, 2011
    1,426
    363
    Just google capillary tubing.
    JJoll likes this.
  8. shortbus
    Sep 30, 2009
    4,095
    1,682
    The TS probably thought the fibers were hollow because they start out a glass tube in the first steps of making them.
    nsaspook likes this.
  9. JJoll
    May 7, 2013
    43
    Flow rate wont matter in my application. It could be slow or fast. I am trying to pump/force regular ink through these tubes. The viscosity of black ink according to this chart (http://www.viscopedia.com/viscosity-tables/substances/ink/) is roughly 5.7mPA.s. The travel distance (tube length) shouldn't be more than 0.5 meter. Also I want the OD to be no more than 0.8-0.9mm. It would be great if you could direct me to a couple of vendors that sell such tubbings. I found a couple of vendors that supply medical tubings with such a low ID but they are very expensive. They quoted me around $50/meter.
  10. JJoll
    May 7, 2013
    43
    thanks I will check this out.
  11. JJoll
    May 7, 2013
    43
    I have never seen or worked withfiber optics and for some reason I always thought they are hollow inside:rolleyes:
    shortbus likes this.
  12. hp1729
    Nov 23, 2015
    2,097
    232
    Oh now, be kind. OP is an engineering student and you know anything they can imagine must be possible, like warp drives, beaming matter or the big bang theory. :)
  13. jpanhalt
    Jan 18, 2008
    5,699
    909
    What do you want the tubing made from? Some of the many options: glass, PVC, modified PVC, Nylon, various stainless steels, silicone rubber, newer Teflon-like plastics, Teflon-lined stainless, various nickel alloys (e.g Iconel). The list is really quit long. If 0.5 mm is your maximum ID, what is your minimum ID?
    John
    JJoll likes this.
  14. Alec_t
    Sep 17, 2013
    5,971
    1,135
    How about this? They may stock smaller ID capillary tubing.
    JJoll likes this.
  15. KJ6EAD
    Apr 30, 2011
    1,426
    363
  16. JJoll
    May 7, 2013
    43
    the material type wont matter to me as long as it is flexible. I was personally looking for silicone rubber or any type of flexible plastic. The Id needs to be somewhere between 0.4mm to 0.7mm. less than 0.4 is not really ideal. thanks
  17. jpanhalt
    Jan 18, 2008
    5,699
    909
    Do you have any remaining questions now that you know where to find tubing with your specifications?
    John
    JJoll and KJ6EAD like this.
