Can I make my linear actuator cycle in and out countinuously?
Discussion in 'General Electronics Chat' started by chdlaser, Jul 31, 2013.
  1. chdlaser
    Jul 31, 2013
    I could use a little help. I have a 12DC, 4" stroke linear actuator. Can I continuously cycle the actuator? If so how?
    Thanks,
    chdlaser
  2. tracecom
    Apr 16, 2010
    3,879
    1,396
    If it reverses direction with a polarity reversal in the power supply, you can design a circuit to swap the polarity at the end of each push stroke, and at the end of each pull stroke. You can do that with limit switches, or perhaps by timing. Is that what you mean?
  3. WBahn
    Mar 31, 2012
    18,089
    4,917
    Is the actualor rated for continuous operation?
    How is it controlled?
    We are not mind readers.
  4. chdlaser
    Jul 31, 2013
    Tracecom - Yes I was looking for a polarity reversal, my thoughts were to use limit switches to control the stoke length. Not sure what limit switches will work for this application. I'll try to attach a pic of my device. I really appreciate your help!!
  5. tracecom
    Apr 16, 2010
    3,879
    1,396
    Generally, limit switches are selected based on the mechanical parameters of the device; lever operated microswitches are often used. Post a link to the specifications for the actuator.
  6. strantor
    Oct 3, 2010
    4,302
    1,989
    They usually aren't.
  7. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Generally that's true for a lot of apps, as people use these for some high load applications (like lifting things). But it can run continuously if the load is light enough that the DC motor runs at a temperature that can be tolerated.
    It's really just a DC motor and gearbox, so like any motor+gearbox it can run continuously as long as load and speed are under the critical values.
  8. strantor
    Oct 3, 2010
    4,302
    1,989
    you are correct. I should have specified "they usually aren't rated for continuous operation at rated load."
  9. WBahn
    Mar 31, 2012
    18,089
    4,917
    My question to the OP still stands. Is the actuator he want to run continuously rated for continuous operation (at the load he is going to be subjecting it to)?
  10. Bernard
    Aug 7, 2008
    4,241
    414
    Does acturtor have built in limit switches? If so monitor motor current via low value sense resistor; every time current falls, trigger a toggle flip-flop which then controles either a relay or H Bridge.
  11. ramancini8
    Member
    Jul 18, 2012
    447
    119
    Another fly in the ointment; cycling causes much more power dissipation in the coil than continuous use does because you have the constant starting current.
  12. tubeguy
    Nov 3, 2012
    1,157
    197
    Yet another fly.
    Running continuously and immediately switching the motor direction is harder on the motor and gearbox than intermittent operation. It would be good, at the very least, to have a short pause between direction changes, or if possible to detect near the end of travel and provide some deceleration and acceleration.
  13. GopherT
    Nov 23, 2012
    6,325
    4,051
    I disagree...
    The constant current runs when you have a continuous current (DC) through a coil and only the resistance of the wire in the coil will be seen as the load.
    When power is applied and the magnetic field is forming, the inductive reactance slows current flow through the coil - until the magnetic field stabilizes. Repeatedly disconnecting the coil without a diode to avoid inductive kickback may cause heating. I doubt the start-up will be a big effect unless the load is so large that the actuator movement is impeded
  14. Brownout
    Jan 10, 2012
    2,375
    998
    ^- You're forgetting that when a motor starts up, work is being done to accelerate the rotor mass and coupled load up to speed. That work is supplied by field current. It's not exactly like a simple coil.
    strantor likes this.
