Hello everybody, Would you give me a hand ?
I need to make a circuit that has Inputs and outputs. I assume that the circuit has 3 LEDs as outputs.
1- When I connect the Input to 1 volt the first LED will light.
2- When I connect the same Input to 2 volts The second LED will light, In this case it doesn't matter if the first LED is on or off.
3- When I connect the same Input to 3 volts The Third LED will light, and also I don't care about the first and the second LED.
The voltage step should not be 1 volt only, It may be 2 volts or any value. I mean if I connect 2 volts the first LED will light. If I connect 4 volts the second LED will light and so on..
Is it possible to make this circuit using transistors ?
What is the schematic of the circuit ? ( Just give me a link or a reference that I can learn how to make this circuit )
