Can I generate 240VAC by feeding 120VAC through a 1:1 isolation transformer to generate 120VAC that is 180-degrees out-of-phase with the mains, tying one end of the isolation transformer secondary to AC neutral (to ground reference it)? I should then have 120VAC with a 180-degree phase shift on the other end of the secondary and 240VAC between that end and the original AC hot wire. Is this OK?
