Can I convert This project below " 10x8 LED Matrix + Arduino" into " 8 X 8 LED Matrix
Discussion in 'The Projects Forum' started by noor22, Oct 11, 2012.
  1. noor22
    Oct 11, 2012
    19
    Hi all
    check please this project
    http://sohilp.blogspot.com/2011/10/tutorial-10x8-led-matrix-arduino.html
    i liked it but the problem is my teacher doesn't want me to work with Arduino . she said try to find like this project " Matrix LED" but by using
    parallel port + db25 + microprocessor
    i want to ask you what Material will i need ?
    i have to submit the report tmw :(
    help me please :(:(
    :) thank you
  2. mcgyvr
    Oct 15, 2009
    4,787
    973
  3. noor22
    Oct 11, 2012
    19
    i get answer from someone
    he said
    Probably yes. You'll need to know how much current/voltage parallel can source or sink. I'm sure it is in the range of arduino, but may be +-12V. Check!
    Serial is another option. Again, it'll probably be RS232 at +-12V. You can get RS232 to TTL converters though, and a serial to parallel chip. That'll let you control your LEDs via a serial port.
    how can i make the new circle with this option
    I asked this person but i didn't get any answer yet:confused::confused:
  4. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    Parallel port is deprecated for years.
    Have a look this: http://pic.hitechworld.org/data/ledmatrixtag
    The source code is included.
    The program is built in a way the matrix size is independent from the scrolling. The image is at first built inside RAM.
    It can be modified for different number of LEDs.
    It should be possible to change for different PICs, and for different controllers. The PIC dependent code is all isolated so you only need to change that.
    If you use my code, feel free to link to the URL.
    noor22 likes this.
  5. noor22
    Oct 11, 2012
    19
  6. takao21203
    Apr 28, 2012
    3,578
    463
    Microprocessor could be anything.
    A microcontroller is a microprocessor, only the RAM + EPROM is built into the chip. And microprocessor are very expensive and difficult to work with.
    There are not many microprocessor LED matrix circuits on the internet.
    An Arduino is an ordinary microcontroller by the way.
    noor22 likes this.
  7. noor22
    Oct 11, 2012
    19
  8. mcgyvr
    Oct 15, 2009
    4,787
    973
    What do you want?.. ALL the information you need has already been provided.. We won't do your homework for you.
  9. noor22
    Oct 11, 2012
    19
    :(:confused:
    I wanted to project the idea close to the idea of the first project
    Be used LED and microprosser
    And the Circle clear it:confused::mad::(
