can I connect the primaries of 2 transformers to the same main outlet as shown in figure?
Only if they are identical transformers.Also, you can add transformers in parallel in case you need more current
A very important detail that I forgot to mention... thanks for clarifying...Only if they are identical transformers.
And phased right!A very important detail that I forgot to mention... thanks for clarifying...
I am bit confused - isn't the way I have added them in parallel? Do you mean the secondaries can be connected in parallel? In the figure above the secondaries on are series, right?Also, you can add transformers in parallel in case you need more current
Yes, in your figure the secondaries are in series. AND if you need more current, you can add parallel transformers to that array. Under the condition that they're identical and phased right, as has been already stated.I am bit confused - isn't the way I have added them in parallel? Do you mean the secondaries can be connected in parallel? In the figure above the secondaries on are series, right?
What's the output voltage that you'd like to obtain ?Ok, thanks.
One more question, can I add 2 primaries in series with ratings of 110/40V and 110/12.5 to reduce the voltage coming out of the 110/40V transformer? I will be using only the output from the 40V secondary.
Your diagram shows the DC in series, if you connect the secondaries (AC) in parallel or series , you will have to phase them correctly.I am bit confused - isn't the way I have added them in parallel? Do you mean the secondaries can be connected in parallel? In the figure above the secondaries on are series, right?
I would like to reduce to about 28V on the secondary.What's the output voltage that you'd like to obtain ?
Would this eliminate the need for 2 rectifiers, since the secondaries are center tapped, I could create a virtual ground on the dc side.Your diagram shows the DC in series, if you connect the secondaries (AC) in parallel or series , you will have to phase them correctly.
Not necessary when connecting series or parallel on the DC side.
Max.
The primaries are in parallel and the secondaries are in series but we use only half of one secondary.You will need to series up one half of one secondary and wire it in series with the other 12.5 to get close to the 28vdc.
Wire them up in SERIES and measure the voltage, if less that 12.5v, swap one pair, then connect to a Bridge rectifier and the caps.
It should result in around 26-28v.
Presuming you want a single supply?
Max.
No, just that the Va rating applies to the lower rated one.In this case does it matter if the transformers are not identical?
by Jake Hertz
by Jeff Child
