Hello all. I'm working with a 4-layer PCB and the two middle layers are power and ground. One of the boards I've been working with just started pulling a lot of current when I connect to power supply. I probed around and notice very low resistance between VDD and ground. Just before this I had done some soldering rework so naturally I thought I created a solder bridge somewhere between a ground and power pin. After scouring over the board for an hour under a lit magnifying glass I could not locate any short that might have been inadvertently created.
Now my suspicion is that heat exposure from the soldering iron might have caused the internal copper layers to expand and either directly short or have decreased the resistance of the material that sits between them. Has anyone ever had an issue such as this?
Anyway to diagnose or treat this problem? Thanks for any insight.
