Can DC Current can be used as analog single
Discussion in 'Homework Help' started by khaqan_shati, Aug 13, 2005.
  1. khaqan_shati
    Jul 6, 2005
    hi : questionis: as in analog to digital converter ,can we produce analog single using DC. if yes then how ?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If I understand your queation properly, yes. A DC level is an analog signal as much a one that is time-varying. In the case of the DC voltage, the A to D converter will produce the same number for earh conversion. This could be useful for a microcontroller monitoring a power voltage level. It would only need to compare the conversion result to a stored number, and generate an alert if the conversion is significantly different from the desired value.
