is this the correct schematic for the internal circuitry of the TL072 op amp? thanks
Z Thread Starter zombiepokla Joined Mar 30, 2009 12 May 15, 2009 #1 is this the correct schematic for the internal circuitry of the TL072 op amp? thanks Attachments TL072 schematic.gif 28.1 KB Views: 66
Audioguru Joined Dec 20, 2007 11,248 May 15, 2009 #2 You show the schematic of a single opamp, the TL071. The TL072 is a dual opamp but probably uses one FET, NPN transistor and zener diode as shown on the right side.
kubeek Joined Sep 20, 2005 5,795 May 16, 2009 #3 This is usually reffered to as the simplified schematic, so there can be a few transistors missing, and you have to find the values of the resistors.
