can anyone tell me why the waveform come out like this way not dc voltage
Discussion in 'The Projects Forum' started by Benengineer, Feb 16, 2016.
  1. Benengineer
    Feb 6, 2016
    101
    I have an original circuits as follows:
    Figure 1 original circuit
    Figure 2 12V supply circuit
    The circuit in Figure 2 provide 12 V to LM258D amp. Input DIMI_L and DIMI_N are from flyback converter output as follows.
    Figure 3 flyback circuit provides power input for the circuit in Figure 2
    When I measured the pin 7 output at its original circuit in Figure 1, its output is dc voltage around 10.9V.
    After I modified the circuits, which Q1 was replaced with 47K resistor and I put diode between pin 7 and the base of Q3. The output was as follows.
    Figure 4 Modified circuit
    Here is the modified circuit output, which is not my expectation.
    Why does its output perform like this way, not dc voltage output? How does this happen? I don't know if this saturated and the top was cut since this is very big output gain. LM258D Datasheet is attached.
    Thank you for your help
  2. GopherT
    Nov 23, 2012
    6,297
    4,019
    So, each valley is about 66 microSeconds apart (at 15kHz). That means, according to my calibrated eye, the valley is about 25 microsecond wide. That means 13 microSeconds going down and 13 microseconds going up.
    The datasheet says the slew rate is 0.3 (min) to 0.5 (typical) volts per microsecond on this LOW POWER op amp. So, let's take 13 microseconds @ 0.4 Volts per microsecond, you get about 5.2 volts down and 5.2 volts back up in another 13 microseconds. Looking at your o-scope output, my calibrated eye is fairly accurate and the datasheet is exactly right.
    You need a slower Pwm frequency or a faster op amp. Note that low power devices are usually slow speed devices.
    Benengineer likes this.
  3. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,678
    1,295
    Why did you replace an emitter-follower pull up device with a 47K resistor? This is a very large increase in output impedance, and introduces a phase shift and low pass filter into the second opamp's feedback loop. Also, what is the function of Q2 in this circuit?
    ak
  4. Benengineer
    Feb 6, 2016
    101
    Sir GopherT,
    Can you have a look at my post? Based on your suggestion, I have slowed PWM. It makes noise much smaller, but the ripple is still there. Please let me know what next step to kill the ripple. Thank you.
