can anyone suggest basic circuit to test a astable multivibrator .
You can get a frequency to voltage converter chip. A certain voltage from the frequency to voltage converter will mean a certain input frequency. The FVC chip does not care about duty cycle so voltage is very accurate.it can be used any where, where we need the clock pulse train of low frequancy.
like a function generator contains.
astable multivibrator is used to produce waveforms
as Astable means the circuit is not set to one state or the other but rather oscillates between those states. Therefore the application is signal generation
