Can anyone identify this component? (board level)
Discussion in 'Automotive Electronics' started by billygoat06, Jun 10, 2016.
  1. billygoat06
    Jun 10, 2016
    9
    I've been having trouble with my car after a dead battery. Come to find out the issue goes into the BCM. It's a 2006 Pontiac GTO. I've taken the cover off of the BCM and found some kind of diode was fried, but that was the only component, and I had traced the pin to the battery power to this burnt diode which leads me to believe it is just something to regulate voltage and also the first thing power passes into in the board. Anyway I'm seeing if someone can identify this diode for me so i can try to replace it with an identical one.
    Here is a picture of what the circuit board on my bcm is supposed to look like. The blue piece in the middle of the board on mine is burned up. there are 3 more off to the side of the board identical to the middle one. they are disc-shaped, blue, and one side reads:
    ^7
    14k
    0543
    I think it's a varistor or a capacitor. It's definitely the first thing that power passes through. Let me know whatever other information you'd need to help me ID this and I can obtain it for you.
  2. recklessrog
    Member
    May 23, 2013
    346
    102
    Are there any identification letters or numbers on it? the picture is small, can you take a close up?
  3. AlbertHall
    Jun 4, 2014
    2,250
    445
    Closer picture, not from directly above.
  4. billygoat06
    Jun 10, 2016
    9
    Yeah sorry took a while to get a good picture, this is it.
  5. ISB123
    May 21, 2014
    1,240
    531
    That are MOVs.
  6. billygoat06
    Jun 10, 2016
    9
    Metal Oxide Varistors? can you by chance tell what they are rated for?
  7. ISB123
    May 21, 2014
    1,240
    531
    You would have to take a better picture of the numbers on MOV.
    But they could be 14V rated MOV's
  8. billygoat06
    Jun 10, 2016
    9
  9. ISB123
    May 21, 2014
    1,240
    531
    Its 7mm size,14V rated and 10% tolerance.
  10. billygoat06
    Jun 10, 2016
    9
    Is the 0543 important to anything?
  11. ISB123
    May 21, 2014
    1,240
    531
    Im wrong. It's size is 14mm but voltage rating is still unknown?
    Take a ruler and measure one of the MOV's.
  12. billygoat06
    Jun 10, 2016
    9
    they do measure out to 7mm
  13. ISB123
    May 21, 2014
    1,240
    531
    Then they are most likely 14V rated.
  14. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    68 - 70V would be a good guess for automotive electronics.
  15. billygoat06
    Jun 10, 2016
    9
  16. ian field
    Oct 27, 2012
    4,447
    791
    If they sell it specifically for automotive use - you have easy comeback if it doesn't perform as claimed.
    The GI range of automotive clamp diodes were usually rated for about 68V withstand voltage.
  17. #12
    Nov 30, 2010
    16,655
    7,294
    I would guess the 5th week of 1943.:D
    No..that's backwards. 2005, 43rd week.
    recklessrog and shortbus like this.
  18. #12
    Nov 30, 2010
    16,655
    7,294
    I see V Nominal DC =22V
    V ndc MIN (V) = 19.8V
    VNDC max (V) = 24.2
    That tells me +/- 10%
  19. billygoat06
    Jun 10, 2016
    9
    So I soldered the component onto the board, seems like a clean solder. Would it matter which way the varistor were oriented? (is one lead positive and one negative?). I'm making sure that isn't a possibility.
  20. MaxHeadRoom
    Jul 18, 2013
    10,820
    2,494
    This might help.
    No polarity observation needed.
    Max.
