can anyone help me with this component...?
flat5
Joined Nov 13, 2008
403
You enter MOC211 into a search engine such as Google.
Like magic, you get links to PDF data sheets for your device.
What an age we live in, huh?
cyril666
Joined Feb 7, 2009
12
i mean how to use it...i already searched data sheet and i want to know proper connection for the device...
for example...if i want to use it as isolation circuit ....how to connect the input and output of digital signal at the end of the device...
DickCappels
Joined Aug 21, 2008
10,180
A simple way to use it is to leave the base connection open. Connect the collector and emitter to a load (for example, ground the emitter and connect a 10k resistor from the collector to a positve power supply, like +5 volts for us old timers), and then on the input side, drive the LED with 10 millamps (ground the cathode, and connect a 330 ohms from a 5 volt power supply to the anode).
Whenever you drive the LED, the collector will go to ground. It will be very close to +5V the rest of the time.
