It's from an electric seat in a car. Again a wrecking yard will have them also, different car models use different length actuators in them. It's worth a trip to a "Pick a Part' type yard to look.
Window actuators in cars are also a good source. They have usually a plastic chain type of mechanism that moves the window that can be cut to any length you need.
Is that a shooting target, reset mechanism your making? Often times you can make a shorter stroke work by adding a bell-crank to the system, if there's room.
