can any one help me to interface 24c04 external memory to pic16f887
Discussion in 'Embedded Systems and Microcontrollers' started by nnnnnnn, May 29, 2009.
  1. nnnnnnn
    May 29, 2009
    15
    this is my example code i cannot able to get the data on hyperterminal.....pls check the code
    #use i2c(master, sda=PIN_C4, scl=PIN_C3)
    #use rs232(baud=9600, xmit=pin_c6,rcv=pin_c7)
    void main()
    int data=0,data1=8;
    output_b(0x00);
    output_low(pin_c3);
    output_high(pin_c4);
    i2c_start();
    output_low(pin_c2);
    i2c_write(0x00);address to external eeprom
    delay_ms(100);
    i2c_write(8); data to the 0x00 th location
    delay_ms(100);
    data=i2c_read(0);
    delay_ms(100);
    i2c_stop();
    while(1)
    putc(data);
    delay_ms(1000);
    puts("hai");
    output_b(data);
    delay_ms(1000);
  2. AlexR
    Jan 16, 2008
    735
    54
    If you want help you should make it easier for people to read and understand your problem.
    Use the advanced formatting option and enclose your code in the code tags (#) to preserve the code formatting.
    Give details of what language and compiler you are using.
    Give detail of what parts work and what parts don't work, also any error messages that occur during assembly and linking.
    A circuit of your PIC connections would also help to eliminate any hardware issues.
  3. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    what compiler are you using? does it compile fine? do you have any code to test the rs232 ( no ). make sure it is working first. have you ever compiled anything that worked ( what ).
  4. nnnnnnn
    May 29, 2009
    15
    sorry sir...i'm using ccs compiler, clanguage.. i compiled sucessufully no error occured..what data i required i cannot get that... i'm using pic16f887 ...
    controller pin 23 portc c4is sda i connected to sda of 24c04 is pin
    contoller pin 18 portc c3 is scl i connected to scl of 24c04
    i connected wp write protect of 24c04 pin to controller c2 and gave low signal to it
  5. AlexR
    Jan 16, 2008
    735
    54
    What are your fuse settings?
    What oscillator are using internal/crystal?, frequency?
    Where do you tell the compiler your clock speed?, for that matter where do you tell it the PIC type?
    Is MCLR pin pulled high?
    How are you connecting to the PC? A circuit diagram would help.
    Try getting the PIC to PC link working without the I2C code and EEPROM. Once it works and you see data coming into your Hyperterm then you can worry about the EEPROM
  6. nnnnnnn
    May 29, 2009
    15
    i'm using 4mhz crystal......no i have not pulled MCLR PIN HIGH.....i'm new to microcontroller.....why i should pull out high the mclr pin sir.....
    at first seperately serial communication is working when i add i2c code its not working....
    now i can write and read the data of external eeprom in hyperterminal but problem is i can write and read only on 0x00 address
    i cannot not write and read in other locations
    thanks in advance
  7. nnnnnnn
    May 29, 2009
    15
    pls help me out.......
    thanks in adavance
  8. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    Assuming your I2C protocol is operable, you cannot do a write / read (or vise versa) in one operation. You must readdress the device, with the appropriate r/w bit set. When you perfrom an operation at some location, if successful, the device autoincrements, so you would need to readdress the device to return to the last location.
  9. nnnnnnn
    May 29, 2009
    15
    alberto sir.
    i can able to read/write 0x00 address sucesfully.......mclr pin is pulled out with resistor sir .........but i can'nt able to read other adress sucesfully ......help me out sir
    thanks regards......
    thnaks for replying my questions......
  10. nnnnnnn
    May 29, 2009
    15
    getdeviceinfo sir..
    ya i changed oxoo to 0x01 when i change address its not get write in eeprom i can sucessuflly read and write in 0x00 address
  11. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    if in fact you can write/read the first location, then I would try a sequential write/read. The code as you've posted it will not work, so I assume that was just an summary. Care to post the actual code that write/reads the one location?
