The guys that sell these things lie about their effectivenessHi MikeML,
I'm not sure what you mean with over promoted and over sold. Can you please explain.
A plug-in type protector inside your house is just another antenna for the lightning pulse to induce energy into if it's not properly connected to a central grounding point.Hi MikeML,
Possibly... L. rods, are the devices resembling a radio antenna you see atop things like barns and houses in rural areas like farmland. Also on some cell towerspackratking
What is lightning rods, is it the same as earth spikes
That is debatable. I believe that an elevated lightning rod is more likely to attact lightning, i.e. increasing the probability of a strike. The goal is to make the strike less destructive than it would be without the lightning rod.Interestingly enough, lightning rods help to eliminate direct lightning strikes.
They create a corona discharge that prevents the potential difference from building up too high.
EGAD !! Are you sure of this ? Most all of the lightning conductors I have seen are done with several braided # 10's, resulting in something on the order of a 6 aught [ 000000 ] cable...That is debatable. The conductor is usually a bare #10 or larger Copper wire connected at one end to the rod, and at the other to one or more 8ft copper-clad ground rods driven into the earth. It is routed on the outside the structure being protected. ???
The more circular mills, the better. It depends a bit on where you are, and the magnitude of the storms. The peak current in a strike ranges from 10KA to over 200kA, in a pulse lasting about 40us. A #10 Cu wire is not vaporized by that pulse.EGAD !! Are you sure of this ? Most all of the lightning conductors I have seen are done with several braided # 10's, resulting in something on the order of a 6 aught [ 000000 ] cable...
An amateur guessing, does the " skin effect " apply to that magnitude of volts and amperage ? and wouldn't the ground stake have to be solid copper ?
The more circular mills, the better. It depends a bit on where you are, and the magnitude of the storms. [[ we get some doozies ]] The peak current in a strike ranges from 10KA to over 200kA, in a pulse lasting about 40us. A #10 Cu wire is not vaporized by that pulse.
A lightning strike causes extreme ground gradients, if it hits anywhere near the power cable that eventually gets to your house, the entire mains wiring of your house is elevated to a severe transient - meanwhile other services such as phone lines, water pipes etc nowhere near the strike are not.It's not something I worry about in the UK I just carry on as normal and I've never had a problem.
On the other hand your thunderstorms are possibly more intense and your power grid a little less reliable?
You ain't just a whistlin' dixie ANY corroded connection in the circuit will not survive...Just put a corroded connection somewhere in the ground wire if you want to guarantee fireworks.
As an aside, I and a couple of friends used to chase spots where lightning had struck the ground, to see if we could dig up the " Fulgurites"
by Jake Hertz
by Aaron Carman
by Robert Keim
by Jake Hertz
