I have just repaired a burned out trace on the main PCB of a kitchen robot leading to a pair of serial connected resistors.
The robot in now working but the resistors are overheating to a point that they smell. I do not think this is normal and I wonder if I should replace them or look at what is causing this to overheat.
Can a resistor's value decrease as it deteriorates?
