Can a pile of consumer electronics be powered from a single supply?
strantor
Joined Oct 3, 2010
6,798
I've migrated most of the electronics from around my house to one central mothership cabinet. Right now in my cabinet I have two full power strips to accommodate all the wall warts for all of this crap:
HDMI splitter
Router
Cable Modem
DVD Player
Karakoe Box
Laptop
NAS
USB hub
POE Ethernet Switch
IP Camera
USB over IP Device Server
Projector
DVR
I'm thinking of adding a couple of more gadgets to the mix:
IR Blaster
Raspberry Pi
Printer
It already looks like a mess, and adding a 3rd power strip would put it over the top. All of these devices operate on 12VDC or 5VDC. I'm wondering if I am likely to encounter any problems if I were to chop off all the wall warts and power everything from one or more large ATX power supply(s). I'm concerned about making supply voltage common to devices that communicate with each other. For example, with the HDMI splitter, DVR, and Projector all being powered from the same supply; in the absence of the isolation provided by the host of wall warts, is there a chance that the Splitter, DVR, or Projector shorting one another out through the HDMI cables?
Is there increased chance of noise?
What issues could I face in doing this?
30,806
I don't see a problem except the heavy current draw. Use a star configuration or make sure you use heavier cabling such as 10-12 AWG for bus runs.
MikeML
5,444
Huge potential ground loop causing hum.
Also, before adding each item to the mix, you need to determine that 0V from each device is connected to the ground side of any other input/output connection to that device, because after you cut off the wall-wart, you will effectively short all the 0Vs together...
MikeML
5,444
there is already a common power supply for these, the ac outlet on the wall.
Yes, but each wall-wart effectively provides transformer (Ohmic) isolation between all the components. Throwing away the individual wall-warts and replacing them with one big common DC supply forces you to connect all of the individual oV nodes to a common oV output from the supply (actually, all of the +5V nodes have to be connected, too). This introduces a potential common-mode noise voltage on each of distal components because of the IR drops along the individual wire runs back to the power supply.
30,806
That is why I suggest a star configuration. Two wires, Vsupply and GND, for each load goes all the way back to the power supply.
MikeML
5,444
That doesn't eliminate ground loops, just minimize them. Suppose you have two items A and B, each with its own ground wire going to the the supply. Wire A doesn't carry ground current for B and vice versa (good). But the common-mode voltage between A and B is still the IR voltage drop across ground wire A + the IR voltage drop across ground wire B (bad).
#12
Joined Nov 30, 2010
18,224
Without reading the thread:
I did this for a guitar player with lots of different stomp boxes. The method was to make a bipolar +/- supply and use those 2 row pin headers with tiny jumpers to assign each output positive center or negative center. It worked.
Just a hint. Might work for you, might not.
strantor
Joined Oct 3, 2010
6,798
Not that it's any of my business, but why??? --- Just curious...:)
Best regards
HP
So that if someone breaks in, they will get all my gadgets all in one convenient place without hunting. Also so that if something catches fire, it will burn my entire system.
</sarcasm>
The reason is mainly because I'm lazy. This is a work in progress home theater/home automation project. I want all my network devices hardwired but I don't want to crawl around in the attic running Ethernet cables.
Also I have two toddlers and they are fond of rooting around in cables and unplugging things and chewing on power conductors. The less things I have plugged into the wall at toddler level around the house, the better. The more things I have protected inside a locked cabinet, the less things I have plugged into the wall around the house.
RayInMS
Joined Dec 12, 2012
89
</sarcasm>
This may not be what you're looking for...but have you considered fabricating a custom power panel that you could mount inside the cabinet? Outlets are cheap at most Lowes/HDs, or can be had on Amazon (these panel mounts are nice). Maybe use ABS plastic sheets or get someone to (3D) print you a custom enclosure. Bring power into the enclosure from a single wall socket. That way, you can position the sockets so your wall warts aren't on top of each other. Cable ties make things tidy. This way, you keep your supplies isolated via their respective transformers.
alfacliff
Joined Dec 13, 2013
2,458
having one power supply for everything could be bad, what if it fails? one good voltage spike or overvoltage failure could kill all of your stuff.
ian field
Joined Oct 27, 2012
6,536
HDMI splitter
Router
Cable Modem
DVD Player
Karakoe Box
Laptop
NAS
USB hub
POE Ethernet Switch
IP Camera
Projector
DVR
IR Blaster
Raspberry Pi
Printer
An easy way to get started; is concentrate first on everything that's USB powered. I've seen USB wall warts up to 2A, but with a bit of home construction you could build up from a surplus open frame switcher - look for one with at least 5A 5V output. At the very least you should also get a +12V rail, you can use that for some 12V devices - but as someone else pointed out; you have to watch for how the grounded parts are connected inside the device.
Reloadron
Joined Jan 15, 2015
7,517
Using an ATX PSU I can see it working just fine with due consideration to Mike's post regarding potential ground loops. I would also give some consideration to fuses. You come off the + 5 and +12 volt rails of an ATX PSU and I would add a fuse block with fuses for each load. Something like this for a fuse block:
One for 12V and one for 5V bus lines. This way each device is properly fused.
Ron
alfacliff
Joined Dec 13, 2013
2,458
I am pretty sure he has enough common sense for that style of protection..
there are a lot of people who get their tv, phone, internet and such all from the same source. now realizing that one failure will cause thm to not be able to get their internet supplier to report the failure. same with a power supply, they fail sometimes, and all the consumer electronics is off till its going again, even if it dosnt kill various thiings. also, a common point for a lightning strike to destroy most or all at the same time.
tcmtech
Joined Nov 4, 2013
2,867
Given all of the devices are in close proximity to each other and all sharing common power and ground lines I don't see where it will be much of an issue. As far as ground loops go I do not see much on your list that are actually analog audio signal carrying devices and the rest are digital devices that will likely already have the necessary internal signal isolating components in them if they needed such protection.
Over the years and doing experiments with my home theater plus numerous other computer network redesigns so far I have never had a problem combining several smaller load devices to one larger power pack so I say give it a try!
tcmtech
Joined Nov 4, 2013
2,867
I'm not buying the lightning strike theory being all the devices are already sharing common physical connections between each other through their network cabling and so far I have never considered the cheap wall wart power packs to be all that great of lighting protection system any way.
What I am saying is "what if XYZ bad things may happen" is not a very good excuse for not trying to improve or learn things from.
I mean heck "what if" you have a stroke heart attack or get hit by a meteorite in the next few minutes and die? All that worrying about the future negatives would have been for nothing! :p
Reloadron
Joined Jan 15, 2015
7,517
This has something to do with all the eggs in one basket? :)
Always have an alternate plan B.
Ron
ian field
Joined Oct 27, 2012
6,536
Ron
There are some gotcha's with using an ATX PSU - you have to adequately load both the +5 & +3.3V outputs, or the others will sag under load.
When I repaired PSUs for a living, I had a nasty problem with a cheap low rated ATX PSU - not all the 3.3V connector pins actually carried power, one of the pins had the voltage sense wire all to itself. The connector on my test load didn't anticipate this and the unit was powered up with no connection between the 3.3V output and its voltage sense wire - the PSU went bang!
Since then; any time I make up a dummy load, I take the snips and cut the power connector out of the scrap board rather than unsolder the connector - that way, the PCB traces automatically group all the pins that need to be connected together.
