Can a LM2907 be used to show higher/lower than center frequency ?
Discussion in 'The Projects Forum' started by Externet, Sep 6, 2014.
  1. Externet
    Thread Starter AAC Fanatic!
    Nov 29, 2005
    780
    58
    Hi.
    The intention is to use a LM2907 that will turn a LED on when frequency is 60Hz +/- 5Hz and two more leds for frequency being lower and higher.
    Does the LM2907 has any pin useable to tell if input is under or over the center frequency ?
    It is for a adjusting the engine governors in portable generators, to be built in a wall wart case.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    The LM2907 simply takes an input frequency and outputs a voltage that is relative in amplitude to the input frequency, depending upon component selection. I suppose you could add a window comparator to trip at the desired voltages/frequencies.
    Your application simply screams for a microcontroller, used as a frequency counter. You could drive 7-segment LEDs to show what the actual frequency is. Or, you could use something like a bargraph LED to show more of a range.
    [edit]
    See this link for a PIC16F628-driven 5-digit frequency counter:
    http://www.qsl.net/dl4yhf/freq_counter/freq_counter.html
