I destroyed the inverter.
It is 3000 watt continuous MSW.
I accidently put 120 VAC grid power into the on-off switch circuit. I was hooking up an external on-off switch.
There are 2 main boards. On each board a 25vdc electrolytic capacitor exploded.
On one board a SMD transistor burned and a short section of copper tracing.
On other board a large power transistor of some type burned. that one is part of a long line of transistors screwed into a very large heat sink.
How do you replace an obliterated SMD transistor? Can a standard transistor be substituted- wired into the board, if so what type to use?
What do you think? I can post pictures tomorrow of the various areas that have obvious damage.
