Hi all,
I'm looking to hook up a garage door remote on my motorcycle and saw some instructions online about using the high beam switch to accomplish this. They soldered 2 wires onto the remotes circuit board to the button contacts so if those wires touch, it acts like a button press. Then they tap into the wires of the high beam switch so when the high beam is on, it closes the remotes 'button' and opens the garage door. Does that sound right to you?
I first thought that a relay would be needed and hooked up to the high beam switch so that on 12V from the high beam power would close its contacts and perform the button press. This makes it more complicated and finding a place to hide the relay/project box is very difficult on a motorcycle.
So can both circuits use the same switch and not interfere with each other? I'm afraid that hooking the remote into a 12V circuit would fry the circuit board or something.
Thanks!
Thanks!
