camera
Discussion in 'Wireless & RF Design' started by Robert123, Mar 28, 2010.
  1. Robert123
    Feb 12, 2010
    29
    camera ...​
  2. dsp_redux
    Apr 11, 2009
    182
    5
    What are your requirements? Want to build everything by hand or use a chip? How much do you know about AM r/t?
  3. dsp_redux
    Apr 11, 2009
    182
    5
  4. rjenkins
    Nov 6, 2005
    1,015
    69
    If it's reasonably short range, how about one of the cheap 'video sender' units designed to link a DVD or sat to a second TV.
    That gives you video & audio one way, plus some have a back channel for infra red remote control.
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    That's not encoding, it's modulating the AM carrier. Do you have any spec's on the transmitter? Is any official organization going to be unhappy about your signal? What frequency are you planning to use, and what country are you in?
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Why do you need to worry about digital modulation? You have told us:
    If the camera has an analog output, doing digital encoding and decoding is just making the job harder. An analog signal can be used to modulate an AM carrier (with some help).
    Without some idea of the camera or the AM transmitter, it's going to be hard to get anywhere.
  7. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Won't work the 433MHz RF units are limited to about 9600baud.
  8. rjenkins
    Nov 6, 2005
    1,015
    69
    That transmitter and receiver have a bandwidth of a few KHz - about the same as a single voice channel.
    An analog video signal has a bandwidth of around 5 - 6 MHz, equivalent to several hundred voice channels.
    You need proper video-rated equipment to handle video signals.
  9. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  10. rjenkins
    Nov 6, 2005
    1,015
    69
    Like I said to start with, a cheap domestic video sender.
    Just search 'video sender' - they are about 20-00 & up here in the UK.
    They take composite video & stereo audio in at one end and give composive video & sterey audio back out the other.
