Camera to TV connection issue
Discussion in 'General Electronics Chat' started by Georacer, Jan 6, 2012.
  1. Georacer
    Thread Starter Moderator
    Nov 25, 2009
    5,151
    1,266
    I have bought the video camera Samsung SMX-F70BP for my family. I want to connect it directly to the TV, a Panasonic TX-29PS11D.
    The camera has an output video adaptor that ends in a composite video RCA connector and another two RCA connectors for Left and Right audio channels.
    However, on connection the image appears black and white. The sound is ok.
    I twisted the connectors a bit, to make sure it wasn't a bad connection.
    Any ideas?
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    It does sound like a frequency response issue. What kind of cable are you using.
    Have you tried it with a different TV/Monitor? It could also be a tolerance issue between the two devices, since color is a single phase shifted frequency embedded in the video signal.
    I got a security video camera too, though I haven't connected yet.
  3. praondevou
    Jul 9, 2011
    2,936
    489
    Wow, I wanted to have a look at the TV user manual. They charge money for THAT?:eek:
    No configuration possible on the TV set?
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    I tried to find the manual online too. Stumbled upon the paysites too. I 'll ask my father if where he has it stored, but I don't know how it will help me.
    As you can see the TV is rather old. Let me think... yes it's 11 years old now, I think. Wow. It has a digital menu though and 100Hz refresh rate. It must have been a good buy back then. Heavy like a bag of bricks, though.
    I don't have a second TV set to test the camera, unfortunately.
    http://downloadcenter.samsung.com/content/UM/201109/20110929180127827/SMX-F70P-ENG_UK_IB_0928.pdf
    Here is the camera manual. On page 77 you can see the cable type. It was included in the camera package.
  5. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
    Has the TV a menu to select the type of video input?
    Perhaps there is a choice between PAL and NTSC or even SECAM.
    Bertus
  6. Georacer
    Nov 25, 2009
    5,151
    1,266
    It does. You can choose among PAL, SECAM, M. NTSC, NTSC and auto. None of them make a difference, though. Of course the NTSC modes cause flickering, this is Europe, anyway.
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    Just curious, how does the color look on the SD card? I'm thinking of you playing the SD card on your computer.
  8. Georacer
    Nov 25, 2009
    5,151
    1,266
    I have successfully played colour videos on the camera LCD panel and stored them in the PC via mini USB.
    I don't think I can blame the tv adaptor. Could it be the age of the tv?
  9. R!f@@
    Apr 2, 2009
    8,791
    771
    Show me a photo of the connector, the camera and the TV. Be sure to show me the area, that is the labeling too.
    It must work u know. unless it is a component out.
  10. mcgyvr
    Oct 15, 2009
    4,791
    976
    The problem is 100% NTSC/PAL related..
    I believe your older TV just doesn't support the NTSC to 60hz PAL conversions going on in the camera or adapter.
  11. Georacer
    Nov 25, 2009
    5,151
    1,266
    I took the photos from my phone, connected it to the home wifi, uploaded them through dropbox app and got them in my pc.
    Isn't technology amazing?
    I know that focus sucks. Do you need anything else, Rifaa?
  12. studiot
    Nov 9, 2007
    5,005
    515
    This is not such an uncommon problem when connecting different makes/types of video equipment. It has to do with the polarity of the video signal, some equiment has negative going, some positive going.
    My studio monitor (and some TVs) has a switch for this, labelled Satellite and Video, which are of the opposite polarity. Watching one in the wrong mode kills the colour burst signal.
    go well
  13. Georacer
    Nov 25, 2009
    5,151
    1,266
    Hm... I didn't know that. I 'll tamper with the TV more.
  14. thatoneguy
    Feb 19, 2009
    6,357
    718
    Doing that 10 years ago would have resulted in a thread calling you a liar or a Witch.
    Yes, I do love technology.
  15. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
  16. R!f@@
    Apr 2, 2009
    8,791
    771
    Do you have the camera manual.
    That connection is pretty straight forward.
    U shud not have any issue with that if your TV is MultiSystem and if it is set to Auto in color system settings.
    Unless it is a NTSC 3.58 and ur TV does not have that color decoding, which means it could be NTSC 4.43 only .
    Multi ones have both NTSC 4.43 & 3.58 MHz color carrier
  17. Wendy
    Mar 24, 2008
    20,772
    2,540
    Everyone keeps referring to NTSC. As far as I know Greece used to be PAL.
  18. R!f@@
    Apr 2, 2009
    8,791
    771
    I don't think the cam is set to PAL.
    If it is then Geo shud not have any issue
  19. Georacer
    Nov 25, 2009
    5,151
    1,266
    I can't imagine how those two signals could be separated. The connection is pretty straightforward: Camera->included cable->TV. I haven't messed with anything beforehand.
    I posted the camera manual on post #4. Greece works with PAL, so NTSC talk is futile.
    The TV isn't as old as I expected. It's approximetely 7 years old after all. I can't find anything on the camera that says that it records on PAL. But when I tell my TV to play on NTSC the image flickers badly, so I assume the camera writes on PAL.
    Thanks for all your trouble thinking for me guys, but I guess I 'll admit a camera and a TV have beaten me.
  20. R!f@@
    Apr 2, 2009
    8,791
    771
    Hey.....this is AAC, we never give up...
    You being a MOD ...shame ....shame.....on you.
    Just you wait...lemme go through again.....
