I must have been confused about your application. Instead of light sensor I should have wrote light switch.
I did not realise there was no permanent power supply available.
It would still be possible to run it off a large capacitor bank. The cap bank powers the cap multiplier. The time constant of the cap multiplier must be less than the cap bank. The cap bank must provide at least 7.5V. If designed correctly the output would appear to have a fast rise time.
If the supply output is less than about 4.5V the zener does not conduct.
When it exceeds 4.7V it starts conducting. (Between 4.5V and 4.7V it conducts a very small current.) The zener shorts out the supply hopefully blowing a fuse somewhere. It needs to be big because it might have to short out for 5 seconds or more before something goes.
In a way, yes. But powering it from a battery pack would mean the camera was effectively powered from said pack.This capacitor amp depends on an external supply of current that will not be available for my current application, . . . however it could be obtained from a battery pack powered version . . . right?
It reduces ripple and noise. Think of it like adding a 10,000µF cap across the supply rails. It's not identical, but it's similar.I am using linear rectifier (7v 800mA P.S.) so that helps with the ripple, but more filter is always welcome.
- Does it help with ripple & noise or just ripple?
The zener goes in parallel with the supply output.Wow 5 watts, why so big?
I like the idea of the 'fuse'. The regulator is protecting the cam too, right? (unless of course it fails, which makes a case for the zener)
Yes it would also work with a battery and PIR sensor.A) If I am right about your impression of my installation environment than the circuit you are describing would be much better suited for a battery operated unit since it is so power efficient. How hard would it be to drop in a PIR sensor that powered the camera for say 4-5min when motion was detected?
