Camera battery pack voltage dropping
Discussion in 'The Projects Forum' started by lentilbake, Apr 8, 2006.
  1. lentilbake
    Apr 8, 2006
    I have an (old but still worth keeping) Fuji Finepix 4900 which
    uses the 3.7v NP80 type Lithiunm Ion battery. The problem is that
    even with a new battery freshly charged the shooting capacity
    is pretty bad.
    I'd like to make an external battery pack to run the camera from 4 x AA sized, high capacity, NiMH batteries which would give 4.8V so I'll need to drop the
    voltage to 3.7V as efficiently as possible. I'm going to use a dummy battery to pick up the contacts inside the battery compartment and run wires to the pack.
    I'd like to know the best way of doing this with the minimum of components.
    The camera is rated at 5V 4W (from the plate on the camera bottom).
    Any help would be appreciated - not too technical, practical if possible.
  2. paultwang
    Mar 8, 2006
    80
    I'd just plug them in :)
    The camera is rated 5 volts
    Your 4xAA NiMH batteries are rated 4.8 volts but in reality is approximately 5.48 volts no load. ... Close enough.
    If you want 3.7 volts, use 3xAA NiMH batteries instead.
  3. lentilbake
    Apr 8, 2006
  4. paultwang
    Mar 8, 2006
    80
  5. diciba
    Mar 14, 2009
    Just get a new good camera battery for your camera life. i won't wate much time.
