calling all experienced builders !!
Discussion in 'The Projects Forum' started by rjsbasso, Sep 13, 2010.
  1. rjsbasso
    Sep 13, 2010
    hi,
    i am looking to build a circuit that takes an audio 3.5mm jack, and filters the frequencies so that it sends a small electric impulse when it registers a certain frequency. ideally over 3 octaves, i'd have a circuit that could tell when 36 different frequency ranges are being played. (probably 4 or 5 octaves now that i think about it, so 48 or 60 different ranges)
    or would it be easier to write a program that does this, and then somehow have my computer send the impulses via a more simple circuit?
    is this even feasible?
    i do not have much experience with circuits but i do know how to solder.
  2. wayneh
    Sep 9, 2010
    12,396
    3,246
    IMHO, you'll be FAR better off using software on a computer than trying to devise your own circuit (design, test, build, etc. - a LOT of work). If you look around, there may be software that already comes very close to what you want. I'm thinking of a graphic equalizer display that shows the relative volume of a number of frequency bands. You want a lot of bands, but there are some pretty sophisticated sound analysis tools out there.
    IF you get skunked and cannot find exactly what you need, only then would I start looking into building my own solution. I'd start with the open source community if it becomes necessary to do some programming. You might find someone that is already close.
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    I agree with wayneh.
    Check out mik3's blog and videos. He built an LED audio spectrum analyzer using a PIC18.
    Link: http://forum.allaboutcircuits.com/member.php?u=17813
    Source code for the PIC is in his blogs.
    The learning curve for uC's is a bit steep, but the use of them eliminates most of the components that would otherwise be required.
  4. rjsbasso
    Sep 13, 2010
    thanks! although i have no clue what to do with the code.
    is there any literature on the web that could help me figure out what to do with the code? or maybe something that can help me understand what's going on in the first place wth the code...i don't really know what uC is and i have a loose grasp on FFTs
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  6. marshallf3
    Jul 26, 2010
    2,358
    201
    Almost sounds like something you'd see incorporated into professional MIDI processing software.
  7. wayneh
    Sep 9, 2010
    12,396
    3,246
    Yup, that's my point: there are a lot of wheels out there and there's no need to invent another. I'd start by exhaustively searching existing software for what I need. For all I know you can already do what the op wants in GarageBand.
