Calling a .asm file into another .asm file
Discussion in 'Embedded Systems and Microcontrollers' started by Sri_, Sep 18, 2013.
  1. Sri_
    Sep 18, 2013
    Could anyone say whether there is any possibility of calling a .asm file into anther .asm file of other project in MPLAB.
    If possilble could u please state the requuired Directive or Instruction.
  2. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,521
    Doesn't the Include File work for you?
    Max.
  3. Sri_
    Sep 18, 2013
    Hi Max,
    Am a beginner in Mplab. I wrote an assembly prog to clear all the RAM locations and my intention is to use or import this entire code in to the programe of a new project, instead of repeating the same code once again.
  4. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,521
    Put it in an (.INC) include file and add it to the Header file list is one way.
    Then use the #include <filename.inc> in the main program.
    Max.
    Sri_ likes this.
  5. ErnieM
    Apr 24, 2011
    7,436
    1,626
    It is also necessary for the project to be able to either see this other code so include the dot-asm file in your project. That's the easiest way to let the linker know it is there.
