caller id project
Discussion in 'The Projects Forum' started by scales, Jan 20, 2010.
  1. scales
    Jan 12, 2010
    7
    dear all
    i currently doing the caller id with the pic 16f628A. my programming and ic are working very well but my mt8870 decoder is not working. i need some help here. i stay in Malaysia please help if anyone got any idea
    this is the schematic i refer to. thks. i need it urgently.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    How have you been able to determine that the MT8870 is not working? If it's not working, how can you tell that the 16F628 is working properly? Do you have the means to see if the DTMF decoder is sending data?
  3. scales
    Jan 12, 2010
    7
    i say that because after i burn the code the inside the ic, the lcd can display the basic information but it just cant display the phone number, so i think that is the mt 8870 decoder problem. do you got any idea on how to test the mt8870 to show that it work properly? beside just test it on the phone line.
    thks for the reply. i very appreciate it.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    I would get the data sheet and verify that the connections in the schematic agreed with the suggested application.
  5. scales
    Jan 12, 2010
    7
    actually now i was confusing is that my code problem or the mt8870 problem.
    here is the code i write for the dtmf decoder
  6. scales
    Jan 12, 2010
    7
    i believe that this code is more detail. please take a look
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Sorry, I do not speak PIC. Perhaps someone else can help at this point.
  8. scales
    Jan 12, 2010
    7
    beenthere
    then can you check for me are that circuit can work properly?
    i really appreciate your help.
    thanks
  9. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Forget the PIC code for now, just test the DTMF decoder by sending a DTMF signal (ie press a button on your phone) and test the IC output pins with a multimeter.
    Once you have the DTMF decoder working properly then you can attach the PIC and go from there.
  10. scales
    Jan 12, 2010
    7
    dear THE RB
    i have tested the dtml with the schematic below and it work well. i just dunno why i connect the Q1 to Q4 pin to the pic abut the lcd didnt show any number. please help. thks
  11. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Sounds liek your PIC is not working. You probably have a hardware or firmware fault.
