Here is the details of the issue. We regularly calibrate the weighing devices to insure the consistancy of the work. The calibration process goes as follows:
We have 50 pieces with standard weight, 20Kgs each which makes a total of 1000kgs, the half of the maximum capacity. We put them in steps and with each step we observe what the indicator reads to make sure that it works properly.
The details of the last calibration process are:
When we put 5 pieces (Standard 100kgs) the indicator reads (99kgs), when we put 10 pieces (Standard 200kgs) the indicator shows (199kgs), when we put 15 pieces (Standard 300kgs) the indicator reads (298kgs) then we put 50 pieces (Standard 1000kgs) the indicator reads (995kgs)
Keep in mind that the tolerance is always kept to zero
So the weighing indicator which we are talking about here is PRECIA MOLEN indicator with the serial number 02F724098
Now I think you have a clear idea about the problem so please send me the ( process installation document) because I just have the user manual here which isn't complete.
