calculator
Discussion in 'Off-Topic' started by kubeek, Nov 24, 2012.
  1. kubeek
    Thread Starter AAC Fanatic!
    Sep 20, 2005
    4,687
    805
    since I started using windows 7, I am allways annoyed by the behavior of the new calculator, namely:
    1) In prorgammer mode, decimal seting, there is no way to use decimal point
    2) if I get a result in one mode, switching to another mode like scientific will delete it.
    I guess they just can´t understand that sometimes you need to mix both binary and fractional numbers.
    Do you have any ideas for a similar calculator (I´d love to keep the way you can see and manipulate bits in the programming mode) that doesn´t have these quirks?
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    RRavi and maxpower097 like this.
  3. ErnieM
    Apr 24, 2011
    7,436
    1,625
    I guess the programmers never calculated a number in decimal that later they wanted to convert to binary or hex.
  4. spinnaker
    Oct 29, 2009
    5,065
    1,174
    I can't stand the new search in Windows 7. Bring back the old XP search.
  5. kubeek
    Sep 20, 2005
    4,687
    805
    Then don´t use windows search at all :D
    I use Total Commander for everything I do with files, so if I need to do a search, I just set up what ever I want like search for .c files, changed less than hour ago, bigger than 20kB, which include the word "timeout".
    Windows 7 search should be a bit faster because it indexes your files, but I don´t think I need to search stuff that often for it to be of any benefit.
  6. strantor
    Oct 3, 2010
    4,302
    1,989
    you guys, ... windows 7? have you seen the calculator in windows 8?
    While I was at my dad's house for thanksgiving he wanted me to troubleshoot his new computer. Windows 8 looks to me like windows mobile stretched out to fit a PC screen. I was pretty lost. Maybe if I had a few hours to sit down with it and figure it out I would like it, but my 5-minute impression is that it's garbage. (no I didn't play with the calculator)
  7. kubeek
    Sep 20, 2005
    4,687
    805
    I that the user interface can be switched to classic mode in W8, but who knows where that option is :D
  8. maxpower097
    Feb 20, 2009
    795
    388
    As an OS calculator its fine. If you want something fancy as Bertus said theirs numerous free and pay calculators that have all the options you want.
  9. Georacer
    Nov 25, 2009
    5,151
    1,266
    I use Windows calculator for one operation type string without parentheses. For anything more advanced I have a handheld Casio nearby.
    maxpower097 likes this.
  10. Wendy
    Mar 24, 2008
    20,772
    2,540
    Funny, that is what I do too.
  11. thatoneguy
    Feb 19, 2009
    6,357
    718
    If you like RPN, Free42 HP 42s emulator
    It's the best non-graphing calc I've ever used. I have a real 42s from college and it sufficed fine.
    If RPN drives you nuts, There are tons of other windows scientific calculators with = sign keys around as freeware, but I haven't tired them.
  12. atferrari
    Jan 6, 2004
    2,663
    784
    What about this?
    Hope it is not the one you are using.
  13. Georacer
    Nov 25, 2009
    5,151
    1,266
    You 're joking, right?
  14. maxpower097
    Feb 20, 2009
    795
    388
    Its definetally not the stock calc in Win 7.
  15. Georacer
    Nov 25, 2009
    5,151
    1,266
    There's even the option to reset to the standard skin. Check it.
  16. atferrari
    Jan 6, 2004
    2,663
    784
    I think you are talking to me.
    THe calculator I had in mind was not actually that. It was offered as a replacement more than a complement.
    It's a pity I cannot find it now. Sorry.
  17. loosewire
    Apr 25, 2008
    1,584
    435
    @ Georacer,at the microsoft down load center,are there any down loads
    that the members could use,Its the first time I have ever scene that site.
