calculation of resistance
Discussion in 'Homework Help' started by kumar158pradeep, Aug 1, 2015.
  1. kumar158pradeep
    Aug 1, 2015
  2. MrAl
    Distinguished Member
    Jun 17, 2014
    2,553
    515
    So what is your question?
    There are a couple different views on this.
    One is as you seem to be stating, another is that some resistances will be lower and some higher, and another is a practical look at resistors where the resistance might be a little lower than rated at 25 degrees C so that it can make it all the way to 100 degrees C without varying more than the tolerance rating (note for a 0 to 100 degree rating 25 deg C is not in the center of that range).
  3. WBahn
    Mar 31, 2012
    18,085
    4,917
    Ditto -- what's your question? And where's YOUR attempt to work YOUR homework?
