The procedure will be to operate the SMPS at its rated maximum output. Careful measurement of power in will show it is greater than the power out. That difference is the loss (in watts).
A temperature probe might supply some insight. Real power loss is converted to heat. Probe the surface temperature of each component, chart the result and then focus on improving the efficiency of the hottest areas.
