calculation of dead band
Discussion in 'Homework Help' started by sudharshan.panduranga, Oct 28, 2009.
  1. sudharshan.panduranga
    Thread Starter Active Member
    Apr 10, 2008
    61
    Hi.....
    Can anyone help to calculate the dead band in sg3525 ic. In need 300ns dead band.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  3. sudharshan.panduranga
    Apr 10, 2008
    61
    is discharge time equivalent to dead band between two PWM pulses??
    is this formula correct? Tdescharge=3RDCt
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    It doesn't seem to quite work out as 3RdCt.
    Even if Rd=0 Ohms and Ct=1nF, discharge time is still 500nS.
    As long as Ct is discharging, the clock output is high, blanking the outputs.
    See page 7 of the Applications Note I linked to, above, under Oscillator.
  5. sudharshan.panduranga
    Apr 10, 2008
    61
    Thanks for reply..,
