Calculation for power consumption
Discussion in 'The Projects Forum' started by j3r, Nov 3, 2011.
  1. j3r
    Jan 9, 2011
    15
    I want to power a device using solar panel. The device's manual stated
    Recommended power supply 24 W, 24 VDC
    Power consumption 15 W maximum
    Obviously i need a 24W solar panel. However i'm kinda of confuse as with Ampere Hour.
    For example, i want to let me device run for 1 day 24 hours on 24Volts @ 1A.
    How do i calculate the required power?
    P = V*I
    I'm missing the duration. Hmmmmm.
  2. kubeek
    Sep 20, 2005
    4,687
    805
    Power is instanteneous. Energy is based on time x power.
    So over 24 hours your device consumes 24x24x1 Wh = 0.576kWh.
  3. j3r
    Jan 9, 2011
    15
    Thanks for the reply. Sorry, i missed out some information.
    Between the device and the panel lies a battery management system. Connected to the battery management system are 2 batteries total having 28.8V (14.4V each)
    I wanted to have the solar panel which can be connected to the battery management system so that it can charge the batteries. However i'm confuse which to choose.
    There's a 32Watt one, 60 watt one...........
    Many thanks!
  4. kubeek
    Sep 20, 2005
    4,687
    805
    It shouldn´t matter, it will only take longer to charge the batteries with smaller-wattage panel. Also the Ah rating of the batteries is another factor in how long will it take to charge them.
