Calculating voltage divider bias, using a thermistor for transistor circuit
Discussion in 'General Electronics Chat' started by Cretin, May 4, 2013.
  1. Cretin
    Dec 13, 2012
    68
    hey all, i have been working on this problem for days now...and it should not be this hard but i can not get it to work.
    I need to design a simple circuit so that when a thermistor is heated with a lighter, its resistance drops and creates a bias voltage of at least .7V volts through an npn transistor, and then this transistor lights an LED.
    Could someone please explain this circuit, how it works, and perhaps even draw a simple schematic? I can only thank you so so much.
    I can't even get the right resistor value, but here are the values you have
    Resistance of thermistor when at room temperature: 4500kohms,
    Resistance of thermistor when heated up: 3500 kohms.
    Resistance of collector: 1000 ohms
    VCC: 5 volts
    I need to find R2, please help lead me through a voltage divider calculation and please help me draw out the schematic. I've spent way too much time on this
  2. Dodgydave
    Jun 22, 2012
    5,143
    768
    Is this an homework project?
  3. Cretin
    Dec 13, 2012
    68
    No Dave, it's part of a side project im working on
  4. Jony130
    Feb 17, 2009
    3,990
    1,115
    Hmm
    4500Komh = 4.5Mohm ??
    Or maybe 4500ohm = 4.5Kohm ?
  5. Cretin
    Dec 13, 2012
    68
    sorry jony, you are correct, 4500ohms = 4.5khm not megaohm...my apologies
  6. Jony130
    Feb 17, 2009
    3,990
    1,115
    First what you need to understand is that BJT transistor don't have "trigger" voltage which turn-ON the transistor instantly .
    In reality BJT start to conduct the current from about 0.5V voltages present between base and emitter (Vbe). And BJT is "Full-ON" when Vbe > 0.6V.
    But I would encourage you to try to build this circuit on the breadboard.
    Where RT is yours NTC thermistor.
    And we can find R1 value quite easily. We simply can use a voltage divider equation.
    You want for 4.5K BJT to be OFF. So we have
    0.5V = 5V * (R1)/(R1 + 4.5K)
    0.5 = (5 * R1)/(R1 + 4.5K)
    0.5*(R1 + 4.5K) = 5R1
    5R1 = 0.5*(R1 + 4.5K)
    5R1 = 0.5R1 + 2.25K
    4.5R1 = 2.25K
    R1 = 2.25K/4.5 = 500Ω
    So we need to use a 510Ω resistor.
    But in real life we a force to use a potentiometer instead of a R1 resistor.
    Why we need a POT? Well the answer is simple.
    Even if you just have a bucket full of transistors of the same type (2N2222). Each of them will have a slightly different turn-ON voltage.
    So we need to use a 4.7K POT and then on the on the bench trim the POT.
    Until we get the desired result.
      File size:
      7.5 KB
      216
    screen1988 likes this.
