Calculating V(0+) in an RLC circuit
Discussion in 'Homework Help' started by saruji, Sep 23, 2012.
  1. saruji
    Oct 18, 2011
    14
    We have just gone over 2nd order RLC circuits in class and I am having a difficult time under standing the 0- and the 0+ of the circuit posted v(0-) is easy its just a voltage divider, but what are they looking for when they ask for v0+? So I assume right after the switch flips the voltage is whatever has built up in the capacitor so in my case 8V as it is parallel with the 4k resistor. Or does v0+ mean that they are looking for v as it changes from 0 to infinity ?
    Problem from my dropbox http://db.tt/DeQ3ODzd
    Thank you
  2. Ron H
    Apr 14, 2005
    7,050
    657
    You have four nodes: The battery (+), a, b, and the one at the bottom, which isn't named. Where is the measurement being made, i.e., across which nodes?
  3. saruji
    Oct 18, 2011
    14
    The measurement is being made at the B node
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    You have gotten off to a poor start. Va(0-) is not 8V. Re-think part (a) of the problem.
  5. saruji
    Oct 18, 2011
    14
    Is it 4 volts?
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    That's correct.
  7. t_n_k
    Mar 6, 2009
    5,448
    783
    The capacitor voltage at t=0+ will be the same as at t=0-
