Calculating Twin-T Oscillator frequency
Discussion in 'Homework Help' started by JDR04, Dec 20, 2012.
  1. JDR04
    Thread Starter Active Member
    May 5, 2011
    339
    Hello everyone. Hopefully this will be the last question for 2012. I've attached it for your perusal.
    I'm required to work out the frequency of oscillation for a twin-t oscillator.
    I've taken it as far as I understand the question but would appreciate any confirmation or comments from fellow members.
    Thanks alot guys. JDR04
  2. atferrari
    Jan 6, 2004
    2,664
    784
    Do you have chances to assemble it in a protoboard just to see if you are in the ballpark?
    I did it several times with that topology. Worked in the first try, always.
  3. JDR04
    May 5, 2011
    339
    Hi atferrari, thanks for your reply. I'm not able to assemble it on a protoboard at the moment. I think the answer is correct but I'm new to this maths and have been teaching myself so I was wondering if my calculations are correct. Thanks again= JDR04
