Calculating transistor resistors
Discussion in 'General Electronics Chat' started by Dritech, May 27, 2015.
  1. Dritech
    Sep 21, 2011
    756
    5
    Hi all,
    I need to use the circuit in the attached diagram where I will be driving the transistor base from a 3.3V GPIO. For the transistor collector I will be connecting a 5V supply instead af 3.3V.
    What equation can I use to determine the resistors values (without assuming resistor values) ?
  2. crutschow
    Mar 14, 2008
    13,523
    3,390
    Nothing is attached.
  3. Dritech
    Sep 21, 2011
    756
    5
    Sorry. I updated the post.
  4. ScottWang
    Aug 23, 2012
    4,934
    777
    Why you not put the buzzer at the c of bjt?
    And how is the V/I of buzzer?
  5. ian field
    Distinguished Member
    Oct 27, 2012
    4,460
    792
    As its an emitter follower; you don't really need those extra resistors - the emitter will follow the base voltage, except that you lose 0.7V in the B/E Vf.
    If you were running at 3.3V the Vbe drop might possibly prevent it working. Even at 5V you could be cutting it fine, in which case a common emitter stage would be better - if your load has to be ground referenced; you'd need a second (PNP) common emitter hanging from Vcc.
    Then it starts getting complicated because the common emiter is inverting, but nothing that can't be sorted out with a few more posts.
    A common emitter does of course require a resistor to limit the current into the base, find out the max current you micro can source and calculate the resistor taking Vout-high and subtractin 0.7 Vbe, and just perform Ohm's law on what's left.
  6. AnalogKid
    Aug 1, 2013
    4,709
    1,301
    If you want the maximum loudness from the buzzer, change the configuration to a common-emitter circuit:
    Eliminate R1 and the connection to GPIO pin 1 (+3.3V).
    Tie the emitter to GPIO pin 6 (GND)
    Connect one end of the buzzer to the collector.
    Connect the other end of the buzzer to +5V.
    Note: the buzzer might have polarity markings. If so, connect the + pin to +5V and the - pin to the collector.
    ak
  7. ian field
    Oct 27, 2012
    4,460
    792
    As far as I can see; the TS is asking how to calculate the resistor values AS IF a common emitter were being used, I think they'll have voltage overhead problems with the emitter follower.
