Calculating time constant in RC circuit
Discussion in 'Homework Help' started by Hitman6267, May 1, 2010.
  1. Hitman6267
    Apr 6, 2010
    82
    I know that T = RC
    I've tried different combinations of R (not really sure what Req to take) but none of them worked. Any one can show me the right way ?
  2. mik3
    Feb 4, 2008
    4,846
    63
    Find the thevenin resistance of the circuit and use it with C to find the time constant.
  3. Ghar
    Mar 8, 2010
    655
    72
    It's the resistance seen by the capacitor. That is, current that wants to go through the capacitor has to encounter what resistance?
    You've got resistance on either side of the cap, so calculate both separately then add them.
    You can ignore the voltage sources, just short them.
    On the right side you have R1 || R2
    <err confused myself, took out what I wrote>
  4. Hitman6267
    Apr 6, 2010
    82
    @Ghar,
    Not sure I know what you're saying.
    We have t>0 so the switch is closed.
    Why can I short circuit the sources ?
    Are you saying Req= R // R // (R1+R2) // (R1+R2)
    And then T = Req X C. If so, I already tried it and it didn't work.
  5. Ghar
    Mar 8, 2010
    655
    72
    You can short the sources because the time constant only depends on the R and C. Voltage sources are 0 resistance.
    Like I said I confused myself so let me sort that out and I can say more...
    Edit:
    So I went to simulate it to confirm and the initial voltage messed me up for a moment.
    Ok so like I said, at the right you have R1 || R2.
    On the left you have an ideal voltage source, so that shorts out the two R's. What's remaining?
    The capacitor loop has the stuff on the right in series with the stuff on the left so you add your results.
    Edit 2:
    Attach a drawing with the current directions... it helps you see what resistances you use and how.
  6. Hitman6267
    Apr 6, 2010
    82
    So you'r saying Req= R1 + R2 + R1 + R2 ( the resistances on the right added with the resistances on the left). I didn't get why it's like that but I tried it and it didn't give me a correct answer.
  7. mik3
    Feb 4, 2008
    4,846
    63
    Short the voltage sources and calculate the resistance between points a and b. The same procedure for calculating the Thevenin resistance of a circuit.
  8. mik3
    Feb 4, 2008
    4,846
    63
    He is saying that Req=R1//R2(left side)+R1//R2(right side)
  9. Hitman6267
    Apr 6, 2010
    82
    Sorry mik3 for not replying to you (slipped my mind after tried to figure our what Ghar said)
    Req=R1//R2(left side)+R1//R2(right side) worked. Thank you both :)
    But could you explain to me the thought process ?
    You short-circuited the voltage sources because they don't affect the outcome. But I don't see how you got Req=R1//R2(left side)+R1//R2(right side).
  10. Ron H
    Apr 14, 2005
    7,050
    657
    It is conventional to use double pipe characters to indicate parallel components:
    Req=R1||R2(left side)+R1||R2(right side)
  11. Thevenin's Planet
    Nov 14, 2008
    183
    From elementary speculation the bridge capacitor is eleminated from the circuit imaginarily,thus the last two branches are in parallel. It seems that all branches are in parallel when following through with what Mik3 said about short circuit the voltage sources.
  12. Hitman6267
    Apr 6, 2010
    82
    That logic would get me R1 + R 2 (left side) || R1+R2 (right side). I don't see how they got =R1 || R2(left side)+R1 || R2(right side).
  13. Ghar
    Mar 8, 2010
    655
    72
    Just to show them in the equation, I'm going to pretend the voltage source has a resistance RV.
    <Was all wrong so I removed it>
  14. mik3
    Feb 4, 2008
    4,846
    63
    You have to find the resistance seen by the capacitor, which in this case, is the Thevenin resistance of the circuit. Just apply Thevenin's theorem between points a and b. You can verify that by simulations or experimentally.
    Hitman6267 likes this.
  15. Hitman6267
    Apr 6, 2010
    82
    @Ghar
    You're saying that everything in the red loop in parallel to R2. For me I see that everything in the red loop is in parallel to the branch that has both R1 and R2.
    About you referring to the current directions you posted. I'm afraid I don't know how the directions can help me understand what you're trying to explain to me.
    i.e. When I look at the picture I don't see a new piece of information.
  16. Ghar
    Mar 8, 2010
    655
    72
    Hold on, I'm trying to redraw it to show it better and I think I made a mistake in my equation with RV. The case with RV = 0 is correct though.
    Edit:
    I'll have to actually derive the equation with RV, I messed up doing it by inspection. What I said only applies with the ideal voltage source.
    This diagram should show why that's correct at least...
    kingdano and Hitman6267 like this.
  17. Hitman6267
    Apr 6, 2010
    82
    oh now I see, I would have never thought of that!
    Thank you a lot :)
    Any chance you could take a look at this thread it's the exact circuit but now am trying to find V and I. I detailed what I tried to do but no success yet. There has to be something I'm missing.
