Calculating thermal resistance of aluminum
Discussion in 'General Electronics Chat' started by dewasiuk, May 15, 2012.
  1. dewasiuk
    Feb 14, 2011
    24
    I have the dimensions for an aluminum heatsink I'm using and I would like to calculate the thermal resistance of it. What formula would I use for this?
  2. crutschow
    Mar 14, 2008
    13,501
    3,375
    Here's a reference that may help you.
  3. THE_RB
    Feb 11, 2008
    5,435
    1,305
    I screw a transistor to them, the transistor has a pot on the base. Then adjust the pot and/or variable PSU until the transistor is dissipating 1W or 10W etc, then measure the temp on the heatsink in varying conditions, ie horiz, vert, with something pressed up against it etc.
    Sometimes empirical measurment is the best, it doesn't take long and can give you real world info that calcs can't always deliver.
    Then when you are done it's only one screw and the transistor and pot comes off and you put it in your junkbox ready for next time. :)
    PackratKing likes this.
  4. mcgyvr
    Oct 15, 2009
    4,791
    976
    I second that...
  5. #12
    Nov 30, 2010
    16,703
    7,339
