calculating the square root
Discussion in 'Math' started by suzuki, Apr 10, 2012.
  1. suzuki
    Aug 10, 2011
    119
    i have an equation in the form of
    A^{2} = B^{2}+C \cos(\omega t)
    what is the square root of this equation?
    the solutions says
    B+0.5\frac{C(t)}{B}, but im not sure how to get this.
    tia
  2. studiot
    Nov 9, 2007
    5,005
    515
    And what might A, B and C be?
  3. steveb
    Jul 3, 2008
    2,433
    469
    It looks like that is an approximate solution for the case where B is much greater than C. Note, I'm assuming that C(t)=Ccos(wt).
    To see this, square the solution, as follows.
    (B+0.5\frac{C(t)}{B})^2=B^2+C(t)+{{C^2(t)}\over{4B^2}}
    Take the case where B is 10 times greater than C. In this case the order of magnitude of B squared is 100, the order of magnitude of C(t) is 1 (or less) and the order of magnitude of C(t)/(2B) squared is 0.0025 (or less). This means the last term can be neglected in many practical cases, provided the assumption that B>>C is met (note that the double greater than sign >> means "much greater than").
  4. studiot
    Nov 9, 2007
    5,005
    515
    Perhaps you understand the half a question better than I did Steve.
    Please tell?
    As a matter of interest if you take the B^2 to the other side and factorise you get
    (A-B) (A+B) = Ccos(wt)
    which leads to
    t = arccos {(A-B) (A+B) /C }/w
  5. steveb
    Jul 3, 2008
    2,433
    469
    It's just a supposition on my part as to what the question really is, but the answer looks like the first two terms of the binomial expansion with power of 1/2.
    There is no way that that answer can be exact, and the type of approximation I mentioned is somewhat common in physics and engineering, but typically is unacceptable in a pure math context.
    I hope the source of the solution makes it clear that there is an approximation involved.
    A good approximation to know by heart is \sqrt{1+\epsilon}\approx 1+{{\epsilon}\over{2}}, where it is assumed that ε<<1.
    This can be used in the following way, in this case.
    \sqrt{B^2+C(t)}=B\sqrt{1+{{C(t)}\over{B^2}}}\appro B\Bigl(1+{{C(t)}\over{2B^2}}\Bigr)=\Bigl(B+{{C(t)}\over{2B}}\Bigr)
    suzuki likes this.
  6. suzuki
    Aug 10, 2011
    119
    EDIT: figured it out, thanks again
    Hello steveb,
    could you clarify in that last step how you went from
    it looks like you divided everything under the square root by B^2 but then how did a B appear outside of the square root?
    thanks again
  7. studiot
    Nov 9, 2007
    5,005
    515
    It's just a bit of algebra.
    \sqrt {{B^2} + C(t)}  = \sqrt {\frac{{{B^2}}}{{{B^2}}}({B^2} + C(t))}  = \sqrt {{B^2}({{\frac{B}{{{B^2}}}}^2} + \frac{{C(t)}}{{{B^2}}})}  = \sqrt {{B^2}} \sqrt {({{\frac{B}{{{B^2}}}}^2} + \frac{{C(t)}}{{{B^2}}})}  = B\sqrt {1 + \frac{{C(t)}}{{{B^2}}}}
    Thanks for the amplification Steve.
    suzuki likes this.
  8. suzuki
    Aug 10, 2011
    119
    to sort of add onto this problem, I am wondering how I can find the amplitude of a sin wave at multiple frequencies. As an example,
    0.01\sin(\omega t)+0.1\sin(2\omega t)+\sin(3\omega t)
    When you plot this, it gives a single sinusoid, but im not sure how i can calculate the amplitude of that waveform
    thanks
    As a visual example, i plotted three sinusoids with the same amplitude but varying frequencies. I cant seem to get a grasp of how i would determine the amplitude of the red plot
    http://imgur.com/YZq85
