Calculating the resulting resistance
Discussion in 'Homework Help' started by activee, Apr 20, 2014.
  1. activee
    Jan 16, 2014
    39
    Hey I'm not sure how to do this, I'm actually blocked at R4.
    I first thought I had to do like R4 and R5 weren't even there but I don't have the right answer.
    I did : R1 + (1/(1/(R2+R6) +(1/(R3+R7))) but that's not right. I got 3600.
    Could you help ? thanks
  2. JoeJester
    Apr 26, 2005
    3,393
    1,211
    Try redrawing the circuit from the prospect of kirchoffs current law
    t
  3. activee
    Jan 16, 2014
    39
    Do the current even go through R4 and R 5?
    Well there will be more current in R3 than in R2. Does that mean that there will be a ddp between the two ends of R4 ?
  4. shteii01
    Feb 19, 2010
    3,500
    511
    You will have to do Delta-to-T transformation.
    R4 and R5 are the easy part. They are in parallel, so find equivalent resistance and replace R4 || R5 with their equivalent.
  5. activee
    Jan 16, 2014
    39
    like this ? R2, R3 and R4 in delta to Y. Same with R5,6,7.
    still not the good answer though
  6. amilton542
    Nov 13, 2010
    494
    64
    This breed of finding equivalent resistance gets tricky here.
    Choose a voltage source of arbitrary amplitude and apply KCL and KVL to find the current through this source.
    Your equivalent network resistance will be V divided by the current through this source.
  7. shteii01
    Feb 19, 2010
    3,500
    511
    I got 2769.4 Ohm.
  8. The Electrician
    Oct 9, 2007
    2,300
    335
    Replace R4 and R5 with a single 5000 ohm resistor; call it R45.
    Now do a delta-wye (same as delta-T) transformation on R45, R6 and R7. DO NOT transform R2, R3 and R4.
    I get 48700/17 which equals 2864.706
  9. WBahn
    Mar 31, 2012
    18,080
    4,917
    Your diagram in Post #5 is wrong. Look at the right hand transformation. Carefully label the three nodes of the delta circuit and then label the corresponding nodes of the wye circuit and ensure that they connect to the exact same nodes in the overall circuit that they did originally.
