Calculating rating of transformer
Discussion in 'General Electronics Chat' started by engineeringcircuits091671, Nov 14, 2012.
  1. engineeringcircuits091671
    Dec 7, 2010
    8
    HI,
    I want to work out the rating of a transformer which has 230V variac
    (do you divide the kva value by the volt value to give amps?)
  2. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
    with single phase, yes
  3. crutschow
    Mar 14, 2008
    13,492
    3,372
    With a Variac you divide the KVA rating by the input voltage (230V in this case) to get the output current rating, not what the output voltage happens to be set at. This means the maximum output current is independent of the output voltage setting.
