Calculating Power consumption of RTC
Siva_sbj
Joined Oct 18, 2007
HI I am designing a battery backup circuit for PCF8583 RTC. The datasheet gives the following info
supply current
(clock mode)
VDD = 5 V 10uA(Typical) 50 uA(max)
VDD = 1 V 2uA(Typical) 10 uA(max)
Typical condition Temp = 25 deg C
I am operating the RTC from 3 V battery.
How could I calculate the power consumption? Is there any formula or method to calculate the power consumption?
Thanks in advance.
bloguetronica
Joined Apr 27, 2007
1,541
supply current
(clock mode)
Thanks in advance.
You should consider the data for 5V, for safety. Then, the power consumption would be:
P = V x I, being V = 3V and I the current for 5V
Hope it helps!
