Calculating permeability of a magnetic core?
Discussion in 'General Electronics Chat' started by electronice123, Sep 29, 2014.
  1. electronice123
    Thread Starter Senior Member
    Oct 10, 2008
    304
    I have a ferrite C core set which has an AL value of 106 and an effective area of 250mm^2.
    Can I calculate the core permeability with just these two values? If not what other information do I need?
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    You probably also need the effective magnetic path length, since for an ideal homogeneous magnetic circuit
    A_L=\frac{\mu_o \mu_r A}{l}
    Where A = effective CSA & l = effective path length.
    There will be a difficulty if the core is intentionally "gapped", since the air gap will dominate the magnetic circuit reluctance.
    If you know AL why would you want to know the permeability?
  3. electronice123
    Oct 10, 2008
    304
    Just trying to find out what it is so I can buy more.
    The core has no gap and is 2 c cores placed together.
    How do I measure/calculatethe effective magnetic path length?
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    To find the path length I guess you take your vernier calipers and make various dimensional measurements of the core(s). Then some maths to work out the likely path mean length.
    Perhaps some manufacturers have cores of similar profile and who quote path length. This might provide additional clues as how to do the calculation.
  5. electronice123
    Oct 10, 2008
    304
    Ok, thanks a lot for the help.
