???Fairly simple.
for parallel resistance, 1/r = 1/r1 + 1/r2 + 1/r3 + ...
for serial resistance, r = r1 + r2 + r3 + ...
Have you looked at the title of the thread?Fairly simple.
I must be having a "dead brain day" just done it again and including turning on the calculator 2213 on the Casio fx83
This is like counting the steps up a lighthouse! can't get the number of strokes right, by dropping the Zero's and mentely moving the decimal point, it's either 23 or twenty four! my brain aches now!So what were the 13? Seems a bit hard to imagine since 1.33, 39, and 17.4 account for 10 and I would think that there has to be at least one key stroke after each numeric value, so that's 13 right there.
I know the feeling. Counting them while I push them increases the chances that I will mess up what I'm doing. So I generally find that just writing them down works best.This is like counting the steps up a lighthouse! can't get the number of strokes right, by dropping the Zero's and mentely moving the decimal point, it's either 23 or twenty four! my brain aches now!
I think we are discounting turning on the calculator, so let's call it 21.I must be having a "dead brain day" just done it again and including turning on the calculator 22
Have you ever tried the Stroop effect by reading colors' names painted in a different color?I know the feeling. Counting them while I push them increases the chances that I will mess up what I'm doing. So I generally find that just writing them down works best.
Sorry I was not clear. I was just trying to point out that if you wanted a 'non standard' resistance value, you could design one from standard value resistors by using the reciprocal of the difference of the reciprocals between a standard value (a higher value) and the one you want.What about it?
Mind showing an example?Sorry I was not clear. I was just trying to point out that if you wanted a 'non standard' resistance value, you could design one from standard value resistors by using the reciprocal of the difference of the reciprocals between a standard value (a higher value) and the one you want.
Yes -> that's explicitly governed by the formula for the parallel resistance.you could design one from standard value resistors by using the reciprocal of the difference of the reciprocals between a standard value (a higher value) and the one you want.
Another approach is to recognize that a given resistance is also a given conductance and conductances in parallel add. So just like it is pretty easy for most people to find a combination of series resistors that combine to give something close to a desired resistance value, it becomes just as easy to find a combination if parallel resistors that combine to give something close to a designed conductance value.Mind showing an example?
Example:Mind showing an example?
Hi,What about the difference of reciprocals?
This is a trivial example, but:
Say you need a 200 ohm resistor, and have the standard 220 ohm part.
1/200-1/220 =4.545e-4
= 1/0.0004545 = 2.2K
220 // 2.2K = 200 ohms.
