Calculating input resistance of an Op Amp?
Discussion in 'Homework Help' started by de1337ed, Feb 27, 2012.
  1. de1337ed
    Mar 6, 2011
    23
    I have the following op amp circuit:
    I was wondering what the input resistance seen by Vs is? How exactly do you calculate input resistance. I feel like it's just ∞ because the second unity gain buffer will force it to see ∞ resistance. If not, how do I go about calculating the input resistance? Thank you.
  2. mlog
    Member
    Feb 11, 2012
    276
    36
    No, the second amplifier has little effect on the input resistance of the previous stage.
    The way to approach this problem is to consider the following:
    1. The input impedance is Vs divided by the sum of the currents through R1 and R3.
    2. The voltage on the inverting (-) and the non-inverting (+) input is the same.
    3. The voltage of the non-inverting input (+) is Vs times R4/(R3+R4). It's a simple voltage divider.
    That should get you started.
  3. de1337ed
    Mar 6, 2011
    23
    I think I might have gotten it. I replaced the input Vs with a Vtest, and calculated Vtest/Itest (Itest is immediately leaving the voltage source). If we assume that i1 is going through R1, then i1 = (R3/(R1+R3))*Itest. We also know that i1 = (Vtest-Vtest(R4/(R3+R4))/R1, so putting them together:
    (Vtest-Vtest(R4/(R3+R4))/R1 = (R3/(R1+R3))*Itest
    and then manipulating to find Vtest/Itest got me Rin = (R1(R3+R4))/(R1+R3).
    Seems good?
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    The final step would be
    Rin=Vs/(i1+i3)
    Which because the Vs terms all cancel, leaves you with Rin in terms of R1, R3 & R4. That's it.
  5. mlog
    Member
    Feb 11, 2012
    276
    36
    I'll go ahead and give my answer. My Zin agrees with de1337ed.
    Zin = Na/Da
    Na=R1(R3+R4)
    Da=R1+R3
    Also interesting is the gain, Vo/Vs.
    Vo/Vs=Nb/Db
    Nb=R1*R4-R2*R3
    Db=R1(R3+R4)
    By the way, Nx and Dx are the numerators and denominators, respectively.
