I'm having a little problem understanding a few examples on my current homework. The problem I get stuck on sounds like this:
"Find the moment of inertia for a circular cylinder of base radius a and height h about a diameter of the cylinder. The density, δ, is constant."
I know I should use cylindrical coordinates and I'm given the formula for the moment of inertia (I = ∫∫∫D^2*δ dV; Where D is the perpendicular distance from the volume element dV to the axis of rotation.) After that I'm stuck.
I checked the answer in my solution manual and the integral is supposed to look like this: δ∫∫∫ (x^2+z^2). Therefore I assume that D^2 = sqrt(x^2+z^2). Why is that? Shouldn't it be sqrt(x^2+y^2+z^2)?
