calculating indication of an ideal ammeter
Discussion in 'Homework Help' started by kawafis44, Mar 13, 2008.
  1. kawafis44
    Mar 13, 2008
    that's the exercise [​IMG]
    and my solution [​IMG]
    calculations for A,B,C (1.1)
    -I_1 +I_3 + I_5 = 0
    -I_3 + I_4 - I_6 = 0
    I_2 -I_4 -I_6 = 0
    calculations for I, II, III (2.1)
    -U_1 -U_3 +0 = 0
    -U_2 -U_4 -0 = 0
    U_3 + U_4 + 25 = 0
    because U_6=0, E_5=25V
    i use resistors R_1,R_2,R_3,R_4 in this formula U_i=R_iI_i
    and i have got (2.2)
    -2I_1 -8I_3 = 0
    -1I_2 -9I_4 = 0
    8I_3 + 9I_4 + 25 = 0
    i try to calculate from 1.1 and 1.2 this current I_6 (i thinks this is what i need to find), but i cannot obtain the result. by the way calculations are too complicated for an exercise like this
    greetings!
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The ideal ammeter looks like a short circuit (or another length of wire). That means the current will only flow in two of the resistors. Ohm's law will let you figure the current easily.
  3. Ron H
    Apr 14, 2005
    7,050
    657
    Come again:confused:
  4. Ron H
    Apr 14, 2005
    7,050
    657
    Here's a big hint. I did it using Thevenin's theorem.
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Probably too rough-and-ready of me, but I looked at the ideal ammeter as a short. That made the current path into the 8 ohm resistor, through the ammeter, and out the 1 ohm resistor. Solve for the pairs in parallel to get the voltage drops, and there is the current through those resistors (the 8 & 1 ohm) and therefore the ammeter.
  6. Ron H
    Apr 14, 2005
    7,050
    657
    I'm not following you. Does that account for the current through the 2 ohm and 9 ohm resistors?
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    No. And on second look, my visualization doesn't look quite so correct. I saw the 8 ohm and 1 ohm as the current path through the ammeter.
  8. hgmjr
    Jan 28, 2005
    9,030
    214
    There are a number of ways to solve your problem but RonH's suggestion of using Thevenin's Theorem appears to represent a straightfoward solution.
    One thing RonH, did you purposefully omit tying the two grounds together in your diagram.
    I have altered you redrawn version of the schematic to show what I am referring to.
    hgmjr
  9. Ron H
    Apr 14, 2005
    7,050
    657
    Oops!:(
    I forgot to draw that in. Good catch!
    Obviously, no current will flow without a return path.
  10. hgmjr
    Jan 28, 2005
    9,030
    214
    I suspect that you had envisioned ground symbols drawn on each of the loops. I had to look at it a couple of time before I noticed there were no ground symbols. After you have looked at as many schematics as you and I have over the years, you tend to overlook a missing explicit connection and assume that they are connected together implicitly.
    hgmjr
  11. Ron H
    Apr 14, 2005
    7,050
    657
    Yeah, I have to confess that after I did the math, I checked my results with LTspice. LTspice won't let you run a sim without a GND. Before I posted, I took all of them out because the OP's schematic didn't have one, and forgot to put in the wire to complete the circuit.
    I didn't actually simulate the intermediate step, but the copy and paste still had GND, which I removed.,
